NZXT Beta EVO
12 Jan 2011
Im currently using a
NZXT Beta EVO as my case and it has some cable managment but im strugeling lol
having finished it yet as cpu is running at 80c for some reason
but the wires for the top fans and the cpu power im not sure how i can make them invisible also the bottom cables that power my fans etc not sure what to do.
has anybody else got this case?
with it being a mid tower its not half as easy to do as big 1's
I Have the NZXT M59 case (mid) and have the same problem (no idea on the cooler though) IS that cooler just a passive.. that could be your problem .. also whats giving you your temp readings
Back to the case i think its just a generic NZXT design flaw my case has terrible cable management upgrading my case soon so not a problem
I have this case, but the first version of it. So the PSU is at the top.
I bought some cable extensions for the 6pin gfx and 24pin atx and routed all my cables behind the motherboard plate. The key is to have cables long enough to stick them out of sight but also be able go where they need to connect.
Would post a pic but my camera had a bit too much fun in the snow recently... :(
Hope this helps!
