- 30 Mar 2016
- East Lothian
I recently installed CAM and was experimenting with the in game overlay which is pretty cool - when it works. I'm using the Acer X34 freesync 3440x1440 monitor it is seems that where the game does not natively support this resolution and I've use a workaround like altering the launch properties in Steam or manually changing the .ini file, that the overlay does not appear. For example I couldn't get the overlay to appear when playing Wolfenstien the New Order or Bioshock.
Also Borderland 2 will not launch properly when CAM is running - the screen keeps freezing although you can hear the game running normally in the audio.
Anyone had similar experiences/know of any fixes for these issues?
