- 29 Sep 2010
- Cumbria
I have a pc that runs windows 7 still for software purposes. The NZXT Cam software auto updates have now made my Kraken unusable for the items it was bought for other than cooling, ie lighting etc. They have realeased a statement which in corporate speak means the user can go and visit a taxidermist.
I get totally that newer versions need to be tweaked for new versions of windows etc, but why are they not leaving a version that works on Windows 7 as it did a few months ago. Even if it is only to sort your leds etc. I don't use the monitoring as it sucks anyway.
I have bought my last item from NZXT after twice getting screwed over by them previously, ironically the last being this NZXT cooler not fitting their own NZXT case. If the item I bought was incompatible with Windows 7 at the time, fine, my issue is they are now leaving me high and dry for no reason other than laziness. Software to switch leds on and off does not need to phone home every two minutes and doesn't need to be 'maintained'.
At then end of the day its a cooler with blingly lights which I thoroughly regret buying. It shouldn't be made obsolete for no reason.
