*** NZXT N450 CHASSIS JUST LAUNCHED - BOLD IS BACK ***
NZXT. NOCTIS 450
Bold is Back.
NZXT is redefining bold chassis design with its new PC case, the Noctis 450. The mid tower case is equipped with a unique blend of modern functionality from an award-winning chassis and a streamlined, yet aggressive, exterior design style. Noctis introduces a new overlay of floating ventilation panels and a generous amount of mesh to bring you an uncompromising blend of design and function.
AWARD-WINNING CHASSIS
The Noctis shares the interior layout of the tried and true H440 – featuring effortless cable management, fully modular hard drive trays, an integrated PSU shroud, and adds on many features to make it a bold choice for any battle-hardened gamer.
10X MORE VENTED SURFACE AREA
By incorporating a floating panel design, we have increased the ventilation surface area tenfold and included four case fans so you can ensure optimal temperatures in your system from the get-go. Gone are the days of restricted air-flow.
INTEGRATED 8-PORT PWM FAN HUB
Want to get more out of your standard case fans? The hub enables PWM signals from your CPU Fan to allow RPM adjustments to your standard 3-pin case fans. For a little extra control, connect the hub to a Kraken AIO Liquid Cooler and make RPM adjustments on the fly with CAM!
ADJUSTABLE LED SYSTEM
With ambient underglow lighting added to the chassis and packed with a multi-step light switch, the Noctis swaps to multiple LED lighting modes with ease.
FEATURES
Read the full product info here
buy the white
buy the black
black:
white:
reviews:
http://www.overclock3d.net/reviews/cases_cooling/nzxt_noctis_450_review/1
http://www.kitguru.net/components/cases/leo-waldock/nzxt-noctis-450-with-kraken-x61-review/
http://www.bit-tech.net/hardware/cases/2015/05/18/nzxt-noctis-450-review/1
http://www.vortez.net/articles_pages/nzxt_noctis_450_review,1.html
http://www.ocaholic.ch/modules/smartsection/item.php?itemid=1627
NZXT. NOCTIS 450
Bold is Back.
FEATURES
- Fully modular hard drive
- Integrated power supply shroud with SSD mounts
- Effortless cable management
- 4 included case fans: 3 x 120mm (Front) and 1 x 140mm (Rear)
- 10X more ventilation surface area for increased airflow
- Fully filtered front air intake
- Integrated 8-port PWM fan hub
- Liquid cooling support: 240mm, 280mm, 360mm Radiators (Front and Top)
- Section adjustable LED system with lighting switch
- Red LED underglow for black case
- Blue LED underglow for white case
- Signature rear I/O lighting
buy the white
buy the black
black:
white:
reviews:
will this be launched on the 28th, or is that when you will announce it
