NZXT F-Panel breakout cable required but can't find one to purchase!
26 May 2008
Hi all,
I have an NZXT H-500 case in black, bought some time back to upgrade my lads old S340, which he decided he preferred, so here I am years later using the case as a stop gap for an old LGA775 build. And with my daughter now asking if she can have the case for her next PC.
Only one problem, the case comes with an Intel F-Panel connector, the one that looks like a small USB 2 header for plugging into the motherboard IO pins, and I have no breakout lead that connects to that which gives the individual pins for the Motherboards I am using.
Any ideas? Is this sort of leadout an item I can purchase anywhere or does it have a specific name. As currently the H500 is sitting with a built PC inside that can only be powered up by using the motherboard power button with the side panel removed, not ideal.
An update, sent an email to NZXT, after a few emails to and fro they sent out the required breakout cable, my old Asus Maximus II Gene system is now temporarilly residing within the NZXT H500 case. Happy.
Big thankyou to NZXT for the customer support! Thankyou freddie64 as the link you supplied showed the exact part.
