- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
NZXT Sentry LX LCD Fan Controller @ £49.98 inc VAT
NZXT, a company built on realizing the dreams of gamers worldwide, is proud to announce the Sentry LX, a high-performance aluminum fan controller. Sentry LX boasts a robust feature set providing gamers and PC enthusiasts with the optimal setup for monitoring and adjusting temperatures throughout the PC.
- Large dual 5.25" LCD screen
- NZXT designed intuitive control, set and change fan speeds and settings on the fly
- Auto/Manual modes, let the LCD take control or set fan speeds to your liking
- Temperature alarm
- Aluminum finish
- NZXT Designed graphical interface, easy to read and understand
- Saved Settings, calender and fan settings are stored even during system off so settings don't need to be redone
- Supports up to 4W per channel
Only £49.98 inc VAT.
ORDER NOW
NZXT Sentry 2 LCD Touch Screen Fan Controller @ £29.99 inc VAT
Introducing the Sentry 2, a full system fan controller with an advanced touch screen interface. Sentry 2 easily installs in a 5.25" bay and is compatible with any fan that uses voltage control. The innovative touch screen features ultra fast selection and response time and displays all pertinent info including temperature readout in both Celsius and Fahrenheit.
Sentry 2 allows users to control up to 5 fans with the option for manually tuning individual fan speeds or letting the automatic controls take over to correspond to a specific temperature. The controller's advanced functionality sounds an alarm to alert the user should the temperature exceed a preset amount and stores saved settings even after it is turned off.
Designed to maximize efficiency, the Sentry 2 supports 10W per channel and creates less heat than traditional temperature displays.
- Touch screen interface
- Five fan control through an intuitive interface
- Ultra fast selection and response time
- Display temperatures in both F and C
- Light switch turns off the meter when sleeping
- Automatic and manual modes of control
- Full compatibility with all types of fans using voltage control
- With a minimum of at least 10 Watts per channel, the Sentry 2 will support almost all high end fans
- Tuned accuracy with only a tolerance of one degree
- Sound alarm to alert when the temperature is over
- Stored settings, the Sentry keeps your settings even after power off
Only £29.99 inc VAT.
ORDER NOW
NZXT LXE Touch Screen External Fan Controller @ £49.98 inc VAT
Introducing The Sentry LXE, a high performance external fan controller with an intuitive touch screen. Its unique patent-pending PCI card interface desktop design allows effortless control without having to reach underneath the desk to configure the settings. Some of the additional advanced features include touch screen capability, 5 channel fan control and temperature detect, time and date display, temperature alarm, and screen on/of functions.
- Intuitive Touch Screen LCD
- Complete Control
- Temperature Alarm
- Sleek Design
- Rechargeable Battery
- Fan Adjustment Range: 3.7V to 12V
- Fan Channel: 5
- Temperature Module Channel: 5
- Measurement Frequency: Every 2 Seconds
- Screen Size: 5.27" Touch Screen
ORDER NOW
- Temperature alarm
- Aluminum finish
ORDER NOW
ORDER NOW
- Complete Control
- Temperature Alarm
- Sleek Design
- Fan Channel: 5
ORDER NOW
