**NZXT FLOW CASES**
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hey Gang
It gives me great pleasure to announce a full refresh of NZXT case products at OcUK.
Previously we were only carrying a few lines from them and stock supply was uneven across the range.
We now have all of the key lines from the new NZXT FLOW range with some standout products available.
The new FLOW range is the perfect starting point for a performance system no matter what size case suits your needs.
Some stand out products from the range include:
NZXT H6 Flow Mid-Tower Case​
This is a subtle performance case with dual chamber design, great airflow and no RGB​
NZXT H7 Flow RGB (2024) Mid-Tower Case​
A smartly designed mid tower with plenty of expansion room and clearance for performance cooling solutions​
NZXT H3 Flow Micro ATX Airflow Case​
A very capable, compact MATX chassis with a similar design language to the higher tier Flow cases at an affordable price point​
NZXT H9 Air Flow (2025) Large Dual-Chamber RGB Mid Tower Case​
A top level case ideal for housing extreme hardware with loads of mounting points for radiators.​
Item DescriptionOCUK Part CodeMSRP
NZXT H9 Flow Mid Tower Tempered Glass PC Gaming Case - WhiteCA-1BF-NX£129.95
NZXT H6 Flow Mid-Tower Case - BlackCAS-NZX-01109£89.99
NZXT H6 Flow Mid-Tower Case - WhiteCAS-NZX-01110£89.99
NZXT H6 Flow RGB Mid-Tower Case - BlackCAS-NZX-01111£109.99
NZXT H6 Flow RGB Mid-Tower Case - WhiteCAS-NZX-01112£107.99
NZXT H7 Flow (2024) Mid-Tower Case - All WhiteCAS-NZX-02645£79.99
NZXT H7 Flow (2024) Mid-Tower Case - All BlackCAS-NZX-02646£94.49
NZXT H7 Flow RGB (2024) Mid-Tower Case - All WhiteCAS-NZX-02647£114.95
NZXT H7 Flow RGB (2024) Mid-Tower Case - All BlackCAS-NZX-02648£119.99
NZXT H5 Flow Matte White Mid Tower CaseCAS-NZX-04424£74.99
NZXT H5 Flow RGB Matte Black Mid Tower CaseCAS-NZX-04425£99.95
NZXT H5 Flow RGB Matte White Mid Tower CaseCAS-NZX-04426£99.95
NZXT H3 Flow Micro ATX Airflow Case - BlackCAS-NZX-06397£64.99
NZXT H3 Flow Micro ATX Airflow Case - WhiteCAS-NZX-06398£64.99
NZXT H9 Air Flow (2025) Large Dual-Chamber Mid Tower Case - BlackCAS-NZX-06399£131.99
NZXT H9 Air Flow (2025) Large Dual-Chamber Mid Tower Case - WhiteCAS-NZX-06400£131.99
NZXT H9 Air Flow (2025) Large Dual-Chamber RGB Mid Tower Case - BlackCAS-NZX-06401£155.99
NZXT H9 Air Flow (2025) Large Dual-Chamber RGB Mid Tower Case - WhiteCAS-NZX-06402£155.99
