NZXT G10 GPU Cooler Question
no but it is possible to get a cable to do so unfortunately there isn't an off the shelf solution i believe. You would have to cannibalise parts to make one yourself. personally i just connected mine to a fan controller and leave it at min settings most of the time and i currently don't have heat sinks on my vrms etc.
If you pcb has a 3 pin header on it then yea something like that.
I had something like this with my 4pin header except it split into 2 fan connectors not one.
