** NZXT GRID+ V2 INTERNAL DIGITAL FAN CONTROLLER **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have had countless requests for this product in the product suggestion forum and now we finally have stock.
The Grid+ V2 is a superb addition to any system. Allowing you to control your fans easily via the advanced NZXT CAM software on android or iOS or on your desktop.
Create fan curves, temperature warning points and keep your hardware safe using built in over or undervolting protection.
Best of all, the Grid+ V2 is very small meaning you can discreetly install it almost anywhere in the case
NZXT Grid+ V2 Internal Digital 6 Fan Controller @ £29.95 inc VAT
GRID+ V2 combines intuitive software and variable installation options to provide a simple, unintrusive solution for digital fan control. With CAM support, the GRID+ V2 allows you to name your fans and adjust your fan speeds easily using versatile preset or custom fan profiles.
Six fan ports line the sides of the GRID+ V2, while two included splitters allow you to control up to eight fans using a single GRID+.
Features:
- Custom fan naming allows you to effortlessly control specific individual fans using CAM software.
- Preset fan profiles allow easy control, while our custom fan profiles allow you to create your own fan curve and have GRID+ V2 raise/lower fan speeds based on temps.
- Full mobile control is planned to be released in 2016 on Android and iOS through our CAM Mobile platform.
- Keep your PC safe with built-in over/under-volt and short circuit protection.
-The small form factor of the GRID+ V2 allows you to discreetly install it anywhere in your case, making cable management easy.
Speciifcations:
- Model Number: AC-GRDP2-M1
- Material: Plastic
- Fan Control: Controlled via CAM Software
- Fan Connector Quantity: 6
- Maximum Combined Wattage: 30
- Mounting: 3M Dual Lock
- Input Connector: 12V with Molex 4-Pin connector
- Dimensions: 73mm x 18mm x 73mm
- Product Weight: 94.2g
Includes:
- 5x Zipties
- 2x 3-Pin Female to 4-Pin/3-Pin Y extension cables
- 1x Molex to phone jack connector
- 1x Micro-USB cable
Only £29.95 inc VAT.
ORDER NOW
CHECK OUT OUR HUGE RANGE OF SYSTEM AND FAN CONTROL UNITS
Excellent, mobo/cpu/ram is RMA'd at present, but I never really got on with the Phanteks Hub in the Enthoo Primo, just doesn't offer much control and the gigabyte board is pretty useless with fan speeds too, this is on the list, with a Vertagear SL4000 ( once I get a working PC back ) :)
Wow this looks really neat - has made me think about replacing my Akasa fan controller (not 100% keen on the Akasa's blue LEDs, or the fact that it uses a 5.25 drive slot).
Is the original Grid+ (I guess now the Grid+ V1) now discontinued? I've still got an outstanding order for one of those open. If they're not coming back into stock, I'll have a word with Customer Services and see if it's possible to pay the extra tenner and upgrade the order to one of these bad boys.
the grid [CA-140-NX] is due in soon, but you can always change to the newer one if you prefer it.
Absolutely brilliant bits of kit. Makes life so much more pleasant.
My only wish is that it would work without CAM running and that the minimum fan speed was a smidgen lower. But neither are big deals.
If you have any questions I should be able to answer.
The only thing this needs is a couple of temp probe connectors so that water temps could be integrated into it
In the software can you create curve for each fan depending on CPU or GPU temp?
Yeah, you can set a curve for each channel and each one can be dependent on CPU or GPU temp. Unfortunately you can't set 2 curves for a channel - one for CPU and one for GPU.
I know that was the case with the original Grid+, but I thought the whole point of the Grid+ V2 was to be able to set individual curves for each fan? Otherwise, what's the benefit of the V2 except the wider holes allowing 4-pin fans to be connected without using the extension cables?
Yep, realised after i posted that i have the v1 version - Not this newer one :D
Popped a note into the Customer Service forum this morning asking for the order to be changed, but it's a little more complex as it seems my order's been cancelled at some point but no refund made. I'm sure someone will get to the bottom of it and get back to me - looks like it'll be after all the current ones are gone from stock at this rate though! :eek: :D
