Nzxt H210 / Asrock Z390 ITX / Noctua NH-D15 - fan issues
23 Sep 2005
Fife
I've just installed the above, and having a bit of an issue with the 2 chassis fans.
I've got the 2 fans on the Noctua going into a y-cable, attached to CPU_FAN1 on the motherboard.
The rear case exhaust fan is on CHA_FAN1/WP (which I've set in the bios to Chassis fan)
The front intake fan is on CHA_FAN2
Both chassis fans are 3 pin (the ones that come with the case).
It seems that all fans are running at or near full speed (1300rpm or thereabout).
CPU temp is 30c at idle.
I'm not sure which options to try - have tried changing one of the fans from PWM to DC (the only one which would let me do so) but it didn't seem to make any different, nor did adjusting the fan curves.
To answer my own question, I had the CPU and chassis fans the wrong way around. Swapping them solved it!
