NZXT H440 Mid Tower Case
13 Apr 2009
Anyone have any idea when will be in stock or any other alternatives?
I'm liking the case mainly for aesthetics but similar one would need to fit Galax 970 and Gigabyte Z97X-UD3H-BK
I think they've just ran out as they had at least one of each, bar the red one, a matter of hours ago.
If you want to know, ask in the CS forum.
As for a replacement, 450D? Phanteks Enthoo Pro? There around the same price.
A budget option could be the bitfenix ronin..
If it's the 970 HOF, and you do end up getting the NZXT, just bear in mind you'll likely need to remove a drive bay or two to fit in it. It's about 4mm too big with the bays in.
Thinking of that card and case myself, you just made me realise I should check it'll fit first!
The H440's are back in stock now..
I can vouch for that (and the drive bay comment!)
Edited to add - yes I know it's not that original :-)
In the RED corner:
In the BLUE corner:
