Nzxt H440
12 Sep 2009
Hey guys a quick question for any H440 owners, did any of you add any fans into the roof of the case for extra cooling.
Looking to get one of these cases & I will be using my existing large heatsink cpu cooler & wont be adding a rad into the roof.
Looking at adding a pair of 120mm pwm noiseblockers pulling the air up and out of the case or is it worth adding a couple of 140mm fans instead.
Cheers all :)
Without hijacking the thread. Has anyone fitted a maximus v formula to this case? The case fits a standard atx however the MVF is only slightly e-atx by half a inch. 9.6inch vs 10.1.
I have read on the net that people have however can't confirm of the edge hits the angles portion of the mb tray near the rubber grommets. Looking to upgrade my case and this is the only case that I've fell in love with.
