NZXT h440
15 Nov 2011
Anyone had any luck fitting a Rampage V Extreme in one of these cases? I've seen cases fit 26.4cm wide motherboards fitting in, this mobo 27.2cm.
would this be pushing it too much?
I think it would fit... I don't personally have it but although they are snug cases you can get a surprising about inside them.
I tried fitting one of these - https://www.overclockers.co.uk/giga...ket-2011-ddr4-eatx-motherboard-mb-520-gi.html
Into one.
That board is 26.4CM wide.
I didn't like it and told the guy to buy another case and send the H440 back.
The cable management grommets were pretty much half covered so any cable (24pin for example) that came through them was rubbing hard against the PCB edge.
The motherboard tray has a slope where the cable grommets are along the side and it looked to me like the solder points on the rear edge of the boards PCB could touch the metal of the case motherboard tray.
I took a pic of it and I will see if I can find it.
Edit, found it,
12179112_10205152121298442_1550874004_n_zpssdv5i4ch.jpg~original
So that view is looking down from above.
The Rampage being another 8mm wider will just be worse.
