12 Aug 2020 at 09:43 #1 wizzywig27 wizzywig27 Associate Joined 16 Jun 2019 Posts 118 Is it possible to put an intake fan on the bottom of the NZXT H510 Elite case? Last edited: 12 Aug 2020
16 Aug 2020 at 12:15 #2 doyll doyll Soldato Joined 1 Jul 2011 Posts 8,801 Yes, it can be done. But it would require modifying case bottom by cutting a vent hole for bottom fan. 2x good hi-pressure rated 140mm front intake fans should supply enough case airflow.
