NZXT Hades
27 Aug 2010
Does anyone here have this case? If so what do you think of it? How's the cooling? Would you recommend it?
Thanks
Also, is the 200mm side intake fan a good idea? Wouldn't that disrupt airflow unless it was running at a very low percentage?
The 200mm fan gets lots of air in, but there is a clearance issue with CPU coolers hitting into the side of it.
Just read then that the NZXT Hades supports up to 165mm tall heatsinks. I have a max orb which is 165mm tall :o
EDIT: That's without the fan, so I guess back to the drawing board.
EDIT EDIT: False info on my fan height, it is 92.5mm, so Hades would fit it with fan.
