NZXT HUE RGB Controller + Existing LEDs?
9 Jul 2013
The Garden Tomb
Hi Guys, I currently have 4 strips of Bitfenx Alchemy Green LEDs (connected together to form 2 strips in total) and I was thinking of getting the NZXT HUE RGB Controller (http://www.overclockers.co.uk/showproduct.php?prodid=CA-115-NX), which comes with a big RGB LED strip.
The NZXT HUE only has one output for the LED strip, so I was wondering if it would be possible to control my existing LED strips with either some kind of splitter so I can connect two LED strips to the one port on the HUE, or if I could add the existing LED strip onto the end of the one supplied with HUE.
I realise I won't be able to change the RGB values of my green LEDs, but would the brightness and effects (flash/pulse modes) from the HUE work with them?
Thanks for any help :)
Blazin
This is a question for Tealc, but I would have thought it might be a mission to get it working. Brightness is just duty cycle, so that SHOULD work.
I personally would try to connect your old LED's ground to the NZXT controllers ground and see - but don't blame me if it goes pop!
