NZXT HUSH, interesting indeed....
28 Oct 2005
Scotland
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-NX
Introducing the NZXT Hush, a chassis designed from grounds up to be quiet while having ample cooling. Game and work without all the noise, thanks to the sound dampening foam that is used on the top, side, and bottom panels of the case. Worried about cooling? Not to worry, the Hush is equipped with two 120mm fans running at low speeds while still achieving high levels of air flow. High end gaming requires faster hard drives and power supplies, so we've installed rubber padding near fans and hard drives to further reduce the sound level. The Hush also ships with USB 2.0, Firewire, and HD audio support. Bring more silence to your gaming experience with Hush.
- 8800GTX compatiblity: Dual NVIDIA 8800GTX in SLI may be installed with three 3.5" HDD space.
- Standard Dual 120mm Fans
- Silent dampening foam reduces noise levels inside case
- Rubber padding on hard drive and fans
- Steel Chassis
- Screwless design for 5.25" and 3.5" devices
- Brushed Aluminum in Silver or Black, pick the style you like
- USB 2.0, Firewire, and HD Audio support
£59.99
£70.49 inc VAT
It all sounds pretty good, looks pretty sleek and a nice price also :)
Just read a review of it somewhere, and they were really impressed with it, good cooling and airflow and quiet. And its not bad looking either
Ordered one of these this morning after watching the youtube video on it :)
Will post some piccys tommorow evening once i get it home and all set up
Yeah, I saw this case in the releases and it looks awesome, prob. my favourite looking case on the site but I dont know if I'm willing to shell out £65 on it, I'd be tempted by £50 but I'll more than likely just buy a £40 case then a good PSU.
I think i'm going to pick one of these up when i build my new rig at the end of summer.
Love the blooper reel at the end of the video. :p
