NZXT Hush
1 Feb 2009
toon
Hi
I have been unable to decide on a case, had more or less settled on a silver fortress case but the silver hush court my eye, there doesn't appear to be much mention of these. any opinions? the only real worry for me is whether it would fit many hdds.
thanks
Ally
I have the black hush, but I'd maybe point out the silver hush only has a silver front panel, the side panels etc are actually black.
As for the case, imo it looks very nice, although it lacks any kind of cable management system and overall the airflow isn't overly great.
I just opened the case up and there is space for 5 hard drives, although some of the spaces will be eliminated if a long GFX card is put in.
Hope this helps :D
ah thanks thats great, sounds too small if thats the case , shame must other cases r really ugly. wish i cud find a nice one thats a decent size. :(
i take it its quiet at least?
Restricted fan vents so if there's airflow there will be also turbulence noise and hard HDD mounting so whole case acts as loudspeaker.
And for that kind weight with steel as material whole case has to tinfoil.
Hi
I had a Hush for a couple of days and sent it back(did'nt get it from ocuk).The inside of the case is the same as a £20 coolermaster case so you pay an extra £50 for a door and some badly fitted very thin foam.I bought it because of the positive reviews but trust me it's a bad case not worth the money.If you want a quiet build what about a coolermaster sileo?
thanks guys, not that keen on the sileo bit boxy looking. il cross this one off the list.
