NZXT Kraken X63
16 Jun 2019
I have read many posts and watched many videos, but looking for some advice from you guys.
I have a Kraken X63 AIO - I am getting a bit of pump whine. Having watched some videos they advise to put the tubes at the bottom (which mine is not) - is this the best way to do it and would it stop coil whine?
I am referring to this video in particular:
Edit: Just turned my cooler around so pumps are at the bottom and no difference :(
2nd Edit: Just turned the pump down to less than 75% and seems to have worked
always try to have the pump lower than the top of the radiator. if air is going to gather you need it as far from the pump as possible. That's more to do with pump longevitythan any whine though. Glad you got it sorted.
You need to have the pump below the top of the radiator and also it could potentially be some air bubbles so unscrew your radiator and shake it around, removing the air bubbles...
