NZXT LEXA Aluminium Case
7 Jan 2006
NZXT LEXA Aluminium Case & more case talk
your views on this case , take a look :)
http://www.nzxt.com/products/lexa/
MODEL LEXA SERIES
CASE TYPE MID TOWER ALUMINUM ( CHASSIS ONLY )
FRONT PANEL MATERIAL PLASTIC
DIMENSIONS (W x H x D) 22 0X 522 X 569 mm
COOLING SYSTEM FRONT, 1 X 120 mm (included)
REAR, 1 X 120 mm Blue LED Fan (included)
SIDE PANEL, 1 X 120mm Blue LED (included)
TOP, 1 X 80mm Fan (included)
DRIVE BAYS 11 DRIVE BAYS
4 EXTERNAL 5.25" DRIVE BAYS
2 EXTERNAL 3.5 " DRIVE BAYS
5 INTERNAL 3.5" DRIVE BAYS
Screwless Rail Design
MATERIAL(S) Aluminum Construction
EXPANSION SLOTS 7
WEIGHT 5.8 KGS (W/O Power)
MOTHERBOARD SUPPORT MOTHERBOARDS: ATX, MICRO-ATX, BABY AT
I've seen them around £85 without a PSU and there's some prefitted with lame watercooling for ~£150.
Mul
Quite nice actually,
-Temp reading and a nice button
-120mm main fans and 92mm secondary fans
-Looks quite nice (different)
Needs the right room for it though!
Vinny got one.
Very nice case, a little on the flimsy side but not bad at all.
As Raikiri said its a little overpriced, should have a price plummit then it would not be a bad option at all.
Price £88 with VAT :) Thinking about it , has X 3 120mm fan , must be good for cooling its not easy choosing a case for your p.c
cheap cases, i use to own the NEMESIS ELITE and when it was deliverd, the door fell of its plastic hinges and side panel was very flimsy.
I'm building a pc for a friend and i showed him a pic of that...and now he's set on getting it...his budget for a case was £30!
so he's going from a Antec SLK3000B to that monster!
It will be nicer to build in i suppose :)
Antecs are built really solid, this is a gaming case, so it will be on a par with it.
It has a feeling of £55 to it, not £80. But the price should come down with time hopefully, although for a gaming case I must say it is a nice looking one.
S-H-A-N-E said:
:) Just found out that OC sell NZXT LEXA Aluminium Case , i wonder how many they have sold yet , has any one got one yet ?
I told you they do in the 5th post!
Personally I don't think they will sell many at that price :p
I won't be getting one, unless its free or cheap :p
At the price as Raikiri says I do not think it represents good value for money due to one case, the Akasa Eclipse.
Make it £50 and its a good case, but at that money, no thanks.
