NZXT Lexa S CPU cooler/GPU clearance?
23 Aug 2010
Hey, planning on getting a new cpu cooler. does anyone have any experience with the NZXT Lexa S CPU cooler clearance?
after reading a review on the "Zalman CNPS7X LED CPU Cooler with Heatsink and Fan (9 x 12.7 x 13.5 cm)" via another website. the reviewer claims to have the same case (NZXT Lexa S (196mm(W) X 480mm(H) X 528mm(D))) and that the cooler just about fitted into the case.
NZXT claims the Lexa S to have clearance of "141.0mm (with fan) 166.0mm (without fan)". if anything shouldnt a CPU Cooler fan not make it wider and not taller? :S
also planning on buying a new GPU eventually, does anyone know the clearance for this case in terms for GPU?
thanks.
The NZXT Lexa S comes with a side fan installed on the windowed sidepanel, with this in place you can fit a 141mm tall cooler and without this fan you can get a 166mm tall cooler in it.
thanks, exactly the info i need. completely forgot about the blue led side fan and the computer sits beside the monitor =\
EDIT: just had another look, currently have the stock cooler on but its nowhere near the side panel fan. as in if the stock cooler became taller it would still clear the side panel fan.
