**Describe your problem. List any error messages and symptoms. Be descriptive.**
I am really happy with this new build, however while playing Mad Max with Max settings on 1440P my GPU temps hit 93 Degrees (CPU stayed below 60), now I have 2 fans on the front of the case pushing air in, 2 on the top pulling air out and one on the back pushing air out.
Im wondering if this is the best set-up, would I be better swapping the fans on the top to push moderately warm air in rather than have them suck the air away from the GPU. Im not sure whether this GPU exhausts out the back as ive had cards in the past that either did or didn't.
**List anything you've done in attempt to diagnose or fix the problem.**
Just monitoring so far, considering setting the top fans to push air in so there is an excess for the GPU to exhaust out the back (if thats how it's setup)
