** NZXT MANTA MINI-ITX CASE - CURVY **
OcUK Staff
26 Nov 2014
Stoke
We're happy to unveil the NZXT Manta Mini-ITX chassis. The Manta is the worlds first case to employ curved, structurally reinforced steel panels. This provides a pretty unique look to the case that is definitely eye catching. Support for 280mm radiators at the front and top of the case, 330mm VGA + PSU's is pretty impressive too! Stock is due with us around the 10th February, and stock is pretty limited for the first run!
NZXT Manta Mini-ITX Case - Black Side Window @ £109.99 inc VAT
Forged with groundbreaking manufacturing technologies, Manta is the world’s first computer case equipped with curved, structurally reinforced steel panels. Manta sets a new standard for Mini ITX with a beautifully curved window, elegant silhouette, and expansive interior. Because it’s fitted with NZXT’s award-winning features, Manta guarantees a stunning build that is effortless and ready to show off to the world. Softening the lines, changing the game, putting everything out there for everyone to see. We took ITX to a whole new level with a revolutionary design and uncompromising quality. Think double the internal build space with support for a liquid cooling system; elegant, curved paneling forged of reinforced steel; and the largest windowed panel found on any ITX case…ever.
Plus, it supports dual Kraken X61 280mm radiators to conquer heating challenges no matter how complex your rig is. The result? A clean, easy build that’s as efficient as it gets with blazing performance. Go ahead, show it off.
Features
- New manufacturing technology offers unparalleled build quality
- Elegant, curved steel paneling and window
- Double the cable management space
- Dual 280mm liquid cooling support
- Kraken X61-ready with push/pull capabilities
- Integrated PSU shroud for a beautifully clean build
- Fully filtered, easy-to-remove intake
Specification
- Dimensions: W: 245mm x H: 426mm x D: 450mm
- Material(s): Fully steel plated exterior, steel chassis
- Total Weight: 7.2kg
- Motherboard Support: Mini-ITX
- External Features: 2xUSB 3.0, 1x Audio/Mic, I/O Panel LED On/Off
- Internal 3.5”: 2
- Internal 2.5”: 3
- PCI Expansion Slots: 2
- Cooling: Front - 2x 140mm/120mm (2x120mm included), Top - 2 x 140mm/120mm, Rear - 1 x 120mm (included)
- CPU Cooler Clearance: 160mm
- GPU Clearance: 363mm
- PSU Length: 363mm
- Packaging Dimensions (WxHxD): 295 x 495 x 470mm
- Gross Weight 8.6kg
- Model: CA-MANTW-M1
Only £109.99 inc VAT.
ORDER NOW
NZXT Manta Mini-ITX Case - Black @ £109.99 inc VAT
ORDER NOW
NZXT Manta Mini-ITX Case - Black/Red Window @ £109.99 inc VAT
ORDER NOW
NZXT Manta Mini-ITX Case - White Window @ £109.99 inc VAT
ORDER NOW
CHECK OUT OUR FULL PC CASE RANGE HERE!!!
Quite attracted to the shape, and good to see the windowed version isn't more than the non-windowed version, is there a reason? No complaints of course but this is new to me as windowed variants are usually around £10 more.
They cost the same, so we sell for the sale :)
Looks amazing, but for ITX it's ridiculously oversized. Full ATX PSU? 3.5" HDD support? 2 280 radiators, and one of those can do push/pull?
Look how much wasted space there is in the front - surely the PSU could've gone in there somewhere and free up space under the motherboard to go Micro ATX support. Hell, maybe even full ATX if you sacrificed dual-width card support for the the bottom slot.
Insanely too big.
