NZXT Panzerboox
7 Jan 2009
So i currently have a Coolermaster CM690,Its an alright-ish case but its quite big and uses up a lot of room on my desk and would prefer a smaller case,Yet try and get a case with decent cooling.
So i thought about the NZXT Panzerboox.
Thing is im not sure if it would be a good idea? seen as i have a prolimatech megahalems Rev b with 2x 120mm fans and i also have a HD6950 which is quite long?
What case would you guys recommend? i also consider a Test bench but theyre expensive :/
Panzerbox is a great looking case but the build quality and materials can be a bit dodgy. For example, one of the motherboard stand-off holes doesn't quite line up on my case and I had to do a bit of filing. Also the removable motherboard tray is practically useless as even the arctic freezer 7 won't fit back into the case if you install it outside.
Pros are excellent excellent cooling, but cons are loud noise and no dust filtration.
I'd get a different case ;).
arghh its outa stock.....actually though looking at the desighn of the T60..you can only have the PSU the on way so all the cables are on show at the front,I dont like the idea of that because it will look messy,If only you could turn the PSU the other way :/
So im still looking for a case guys :/
I really didnt want to spend more than £80
