NZXT Phantom 410 Crossfire?
5 Jun 2012
Hi everyone I've just bought 2 hd 6850s for use in crossfire. I really like the look of the NZXT phantom 410 gunmetal case but I was wondering if anyone who actually has one can answer this- would two 6850s fit into the phantom? And if they can what Is te cooling like? Would I need to replace stock fans? If I do is there any red led fans you can recommend (if coloured it has to be red :) )?
The case will certainly support it provided your motherboard does :)
Looks like a good case. If you can I would be tempted to remove the top HDD bay and install another fan there and maybe one in the side drawing air out if you find your 6850's run a little hot. Bitfenix spectra's are good LED fans
I myself heard the spectres were really bad fans? I was thinking of getting the CoolerMaster SickleFlow Red led fans? Btw do you happen to know what colour the included led fan is? Can't find the answer anywhere? And I was planning on buying 4 SickleFlow fans- two for the front, one for the side, and one inside the case (directed at the 6850s). Would the cooling be sufficient then?
