NZXT Phantom 410 worth getting?
15 Aug 2010
Hi :)
When I first noticed this case I just thought "Wow! what a case!" mainly because of its looks. After reading some reviews I gathered that the cable management isn't perfect, but good enough, and cooling and noise is the same too, but are there any other cases which are similarly priced (I have a £100 budget on the case) which offers less noise, better cooling and cable management while having a great look to it?
Thank you for your help
I have the phantom 410 and personally I think it's great! :)
The cable management is great actually but there are two slight issues which I'm sure would have been highlighted in the review.
Firstly the grommets that you pass the cables through don't stay on very well while you pushing cables through. It's not a big deal though. You just push them in once you've finished.
Secondly the motherboard PSU connector at the top left is a bit hard to get to, depending on the length of your PSU cable you may have to buy an extension if you don't want it trailing over the motherboard.
Other than than it's great, my CPU/Case temps are now cool as you like and with the fan speed set low, this case it pretty quiet.
