- 27 Feb 2012
Hey guys, I was looking at the NZXT Phantom 410 and I noticed found out that you can mount a radiator above the top of the case under the plastic (under the lid). I was wondering, does anyone know how much clearance space there is underneath there? I know that you can fit a H100 (25-30mm), but would an EK 240mm (47mm height) radiator fit under there? Thanks in advance as I'm looking for a case that can hold a 240mm rad and has a side window. Everything else for my future build is sorted
