** NZXT PHANTOM 630 @ £145.99 **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have epic pricing on the 630 Phantom range from NZXT currently.
This Premium Full Tower Chassis offers cutting edge design features as well as striking looks.
The Phantom 630 comes in three brilliant colourways which suit any desktop.
Grab yours now!
NZXT Phantom 630 High Performance Modular Full Tower Case - Black @ £145.99 inc VAT
Allow us to introduce you to the future. Presenting the NZXT Phantom 630 – a chassis so revolutionary, it
may just be the last case you’ll ever need. The original Phantom was, in every aspect, undisputed in its design. Bold, striking, timeless, NZXT broke new ground and raised the bar for an entire industry. The design of the Phantom 630 achieves this again while fully satisfying the high demands of those who take
computing seriously. The new Phantom 630 brings support for cutting edge features such as simultaneous support for a 3x120 radiator, a 2x120 radiator and all hard drive bays, interchangeable fully-modular HDD cages, pivoting fan mount, and a single 30-watt controller with four high endurance fans included. Naturally, all other features you expect from a high performance NZXT chassis are in. The Phantom 630 breaks tradition and moves you forward in every way. The future is here.
- Next generation Phantom design, both inside and out
- Fully modular internal drive bays allows you to customize the Phantom 630’s layout to suite your needs
- Full external peripheral support with multiple USB 3.0, 2.0 connections and an integrated SD card reader
- High-end water cooling support allows use of multiple radiators and multiple radiator sizes
- Split-level motherboard tray allowing increased rear cable management
- Illuminates rear I/O ports internal components with a ick of a switch
- Integrated high-power 30-watt single-channel fan controller
- Easily removable dust lters protect your components
- Dual SSD mounts behind the motherboard tray
- Drive Bay: External 5.25" x 4 / Internal 3.5" or 2.5" x 8
- Front Cooling: 1 x 200 or 2 x 140 or 2 x 120mm ( 1 x 200mm included)
- Top Cooling: 2 x 200 or 2 x 140 or 3 x 120mm ( 1 x 200mm included)
- Side Cooling: 1 x 200mm ( Included)
- Rear Cooling: 1 x 140/120mm ( 1 x 140mm included )
- Bottom Cooling: 2 x 140/120mm
- HDD Cooling: 1 x 140/120mm
- Dimensions: 245 x 627 x 600mm
- Motherboard Support: ATX / MicroATX / XL-ATX
- Front I/O Ports: 1 x audio mic / 2 x USB2.0 / 2 x USB3.0
- Built in SD Card Reader with SDHC & SDXC Support
- Single Channel 30-watt Fan Control
- 2 Year Warranty
Was £159.99 Inc. VAT
Only £145.99 inc VAT.
ORDER NOW
NZXT Phantom 630 High Performance Modular Full Tower Case - Gun Metal @ £145.99 inc VAT
- 2 Year Warranty
ORDER NOW
NZXT Phantom 630 High Performance Modular Full Tower Case - White @ £145.99 inc VAT
- 2 Year Warranty
ORDER NOW
The side fan 200mm might block any height air cooler or any high end GPU graphic card?
There is no metion of this case spec for height for air cooler?
I wish the side panel is fully windowed without silly fan on it.
Still too much :p The price tag on this case is crazy.
In fact... The price tag on ALL Phantoms is crazy... :rolleyes:
I disagree, it's a pretty nice case for the right person, if it was my type of case, I'd probably buy it, although the 650D is more my type of thing :p
