NZXT Phantom 630 200mm fan replacement?
5 Dec 2018
Hey all,
I have an NZXT phantom 630 case with a bearing in the top 200mm fan that clicks sometimes when in use. I want to replace it but can't find a straight answer to what I should get. I asked this question once before on another forum but since then it has only posed more questions for me.
The build im planning in the new year is here: https://uk. pc part picker .com/user/Dobby240/saved/#view=kxT7WZ
I would like to do the whole lot at the same time for ease.
So in the last thread i was suggested a Noctua NF-A20 PWM. But their site says it's not compatible (https://noctua.at/en/case/NZXT_Phantom_630)
All that said I'm pretty stuck with what I can get. The fan controller in the back of my case looks like a 3 pin connection and the fan suggeted is a 4pin. Correct me if I'm wrong.
It's not about aesthetics I just want decent cooling that doesn't click. I have space for 2 x 200mm fans so if I can populate both spaces with a couple big brown Noctua bad boys I will.
Anything else I should consider? I've never bought fans nor installed them so tell me like im 10.
ha
Thanks all.
Matt
