NZXT Phantom 820
8 Jul 2014
Hello
I was wondering what you guys think of the aforementioned case also any advise on cable management and little tips for using the case would be greatly appreciated many thanks BM
Overpriced and not as good as its newer little brother the 630 unless you want the LED's etc (you can see the reviews say same).
as above really overpriced and cheaply made in my opinion having owned 2 of them the 630 is the better case
Never seen the 630 but I'd like to be able to expand a lot so the 820 was a preferable choice also pretty colours haha but seriously the lights are a part of the build many thanks BM
The 630 is an Ultra ATX case and I am sure they gave it even more width behind Mobo tray than the820.
They are near enough same size if you take away the raised feet and plastic roof, so actual case size.
Not to say they did cheap out on some things from original Phantom, door is lighter does not feel as high quality and does not open past 90degrees and a few other niggles.
I know you have it now and I am not trying to peeve you off but the 630 is up off ground a good 2" at least but does not sit on a horrid looking sled.
I would never run a PC on a carpet mate, get it up on desk or such looks better (esp with side Window) and cooler running with less dust.
Assume you have no space for it.
