- 19 Aug 2013
hey guys just want some help with the airflow in my case, i have a seidon 240m, mounted on top, and on the side door i have a 200m, and the 2 stock 140m, i also have a sp120 at the front as intake, my question is should i put the 200m from the side and put it on the top, so i would have 2 200m fans on top, and just the 2 140m on the side?.
or have it as it is with 1 200m on top and 1 on the side?
edit: i have a cool master pwm fan from my cpu loop should i put that in the front and the sp120 at the back ?
or should i remove the 200m fan from the top and mount my seidon on the top as pull ?
thanks 181jenkins.
thanks 181jenkins.
