My experience
Spent a day sorting out build - cable management is easy - the build looks very neat & airflow (front to back/top is good). No cuts & ,in summary, no problems!
Decided to remove the smaller of the 2 HD trays/holders as I do not have that many hard drives .
Tried with standard (as it comes) cooling - ok but decided I wanted a little more.:-
1) Put in 140mm at front to pull air in - the reviews I read did say that such would drop temps generally 2-3c it did
BUT the noise level was unacceptable on anything other than minimum and it created what I can best describe as a turbulance/vibration noise (was not sure at the time what was causing this but as it was cured by moving the fan(see below) assume that this was the culprit).
2) Tried fitting, a second, nzxt 200m fan to the side - NO joy - will not fit with a Prolimatech Megahelams cooling the cpu . - Was a little disapointed but having looked at where the fan sits it appears to be more of an additional cooler for the cpu rather than cooling the Gpu (which is what I really want it to do).
Thought that answer could be to buy a lower cpu cooler but I do like the Prolimatech and given the position of the fan ........
3) Then tried the 200mm fan in the top rear slot - sucking in. - Not a good idea increased temps all round
4) Tried the 200mm -top rear + exhaust. - Better than sucking in but not much better, if any , than not installed at all.
Having decided that the rear top fan was not giving any advantage , turned it off and ran for a week with 2 x 120 @ side sucking in + 1 x 140 @ front sucking in and 1 x200 at top + 1 x 120 at rear sucking out.
Temps ok but only livable fan speed is slowest and even then getting some turbulance/vibration noise.
The main noise problem appeared to be coming from the 140mm fan and having given the matter a little thought came up withe thought of replacing it with a 120mm fan
AND placing the now spare 140mm at an angle in the place where the hd cage was so that it would blow additional cool air into the case and , being directed towards it , cool the graphics card.
AND to balance the extra air coming in turn back on the rear 200mm fan as an exhaust fan.
Found fitting the 140mm fan straightforward using cable ties to hold and vinyl door buffers (16 for 79p) to cushion, although a little time consuming. Did also add filters to the floor air vents to avoid sucking in loads of dust.
Having fitted as mentioned started her up at lowest fan setting to find that it's very nearly silent , the turbulance/vibration has gone and the cooling is as good if not a little better than the Haf 932 I was using
Worth a £100 - No- until you factor in the fun I've had and the facts that :-
1. It's better looking than the Haf (imo!)
2. It probably runs a bit quieter - Have no ability to measure the noise levels so cannot say that it is measurably quieter but it sounds it to my ears!
3. It cools as well as the Haf - given the improvement is no more than 1-2 c do not think I can say with certainty that it's better.
4. I will NOT have to clean the whole thing every 2 weeks or so !! ( the Haf was costing me £4-£5 every couple of months in Air Dusters.)
Overall very pleased with my new case
- would be happy to recommend , once you get the airflow right.
I hope others may find the above imfo. of use
N.B. Am running a 470 with standrad cooler at the moment although the intention is to fit the Zalman vf3000 so may find that some re-adjustment is needed.
