NZXT Phantom Compatible Fans
11 Nov 2012
Hi All,
I've looked around for some compatible fans for the sizes to refit as I'm going SLI and need the extra cooling in the long run.
I had looked at the Cooler Master 200mm Mega Flow's as they look and perform brilliantly, however these aren't compatible with the fittings I've read? Has anyone ever 'forced' them to fit?
Also, what would you recommend for a 120mm (bottom of the case fitting pushing air up) and 140mm fan (front of the case fitting pushing air in towards the GFX card's) for the NZXT Phantom Enthusiast?
I'm looking for low sound and good output in both.
Thanks,
Sean
