NZXT Phantom CPU Cooler Compatibility
1 Aug 2010
Been reading certain forums and a lot of people are having difficulties fitting coolers such as Corsair H50/H70 Coolers within the case.
Has anyone had good experiences with fitting certain coolers within there Phantom?
Was purely after the H50 Cooler.
The H 50/70 does fit however it means either moving around or taking out of the 120 mm fan and the 200 m exhaust fan. The 200 is easy enough there is actually a space just to the left of the HD cages which will give sufficient room. The 120 however will have to be removed completly. Wouldnt care to much about this though as there is plenty of cooling around the case as well as another 2 120mm intake fans on the side case.
