nzxt phantom, cpu + gpu help
10 Nov 2011
Telford
The 360 rad I had in has developed a leak so took it out last night.
What rads would U recommend to cool a piledriver 8320 and gtx 670ftw?
Also how to place them in the phantom would help.
Used to have the 360 rad roof mounted
I currently use a 240 & 140 for my CPU and 2 GPUs. Replacing the 240 with a 360 soon which will be going in the roof and I just keep the 140 where the HDD cage was.
Simple enough but needed to cut a hole under the 140 for it to fit.
