Hi guys, I have a 7 year old Titan Scythe Overclocker system and the 200mm top fan makes some fantastic rattling sounds intermittently, I've researched as much as I could to find the replacement and it seems the model is 'FN-200'. FS-200 would potentially fit as well I believe, but FZ-200 is incompatible according to various sites.
However, I haven't found anywhere I can purchase a replacement from except one EU site that is charging something in the region of £40 which I'm not willing to pay if I'm honest.
I know some people have mentioned Noctua fans could work, but I get the impression NZXT designed the case to only be compatible with their own products, so don't particularly want to risk it!
I've recently cleaned the entire system, and I was able to completely detach the fan and clean thoroughly, and I do occasionally put a few drops of sewing machine oil into the ball bearing hole at the top which does seem to help for a time, but it can get a little bit distracting.
Could anyone recommend anywhere?
Thanks in advance,
Jules
Edit: On closer listening, it could actually be some of the other smaller fans, think those are 120mm ones.
Thanks in advance,
Jules
