- 7 Aug 2012
- Jersey, Channel Islands
Hi everyone, just a few queries/problems with the above...
I just bought the 140mm LED fan for the front of my phantom case, however the screws included were far too big and none of the extra fittings that came with the case will fit... I kinda of just sat it in there and put the front back on and it seems okay, just wondering if anyone else had this problem? (if it is a problem or not)
Also I couldn't see anyway of connecting it up to the LED on/off button on the rear which would be nice, as even when the system is shut down the LEDs flash when the fan controller is turned down and stay constant when turned up.
Also my rear fan spins at a low speed when the system is shut down...
Other than these little niggles the case is GREAT and I recommend strongly
Thanks
Rory.
.Thanks
Rory.
