There are only two plastic bits, the top and the front and neither are structural. They are just decorative. The rest of the case is steel and quite well made with plenty of room. This is the first case that I have had with a door so I don't really know how it compares, it is quite solid though and has a little magnet in it to keep it shut.
If you have any other questions just ask and I will have a look for you.
cool i'll have a look at that case. although i do like the Phantom no matter what anyone say's
i know it's an expensive case but what i like about it is it has a lot of room inside and also it has easy access hard drive slots. plenty room inside to fit pretty much anything i want....i think
You will be surprised how quickly all that room disappears when you start fitting everything in it. I am really struggling to get everything that I want in it (there is a lot of stuff to go in there though).
I got mine recently and I love it so far. My only gripe is that it could be a tiny bit wider. My Frio is so tall that I think it would foul a side fan if I installed one... which I would like to do because my GPU gets quite toasty. My HDDs have gotten very cool though coming from my last case
