- 20 Dec 2015
- Hertfordshire
I have a new version of the H440 with the PWM fan hub which i have not been able to make work the way i think it should. My testing has shown the following........
1. Unlike NZXT's advice i have found that there is no need to connect the PWM cable to the CPU header on your motherboard, connecting to any controllable fan header operates the same way.
2. You must have a case fan connected to the white 4 pin fan connector on the hub (fan1) to see rpm of the fan but this only shows the rpm of the connected fan on that particular header.
3. Changing fan speeds via the motherboard BIOS or software only affects the fan on the white fan1 header, all other fans appear to run at full speed, surely it should change all the connected fan's speeds.
I dont think the fan hub works very well, (surely NZXT tested the functionality..........i guess they did'nt!) in fact it seems to be a waste of money which NZXT could have utilised to make the case a little cheaper.
