Hello, I was thinkning about buying NZXT Sentry LX as I really like its big LCD screen, but after reading few reviews it seems like it has got few cons. I have few questions about them?
1. viewing angles are really bad, anywhere above and below and you can't read the screen. My PC is under the desk, so I'd have to sit on the floor to read the screen, I could live with that though.
2. only accepts 3 pin fan connections - I guess I could buy adaptors if that will work?
3. Supports only up to 4Watt per channel, which means only up to 120mm fans (i think). I have 2 x 200mm case fans installed in my HAF 922 so I won't be able to control them, right?
4. Does not support PWN fans and I just ordered 2 Akasa Apache PWN 120mm fans for my Venomous X CPU cooler. Does it means that I won't be able to contol those?
So, do you think it is a good choice for me or there is better fan controller I could buy. I don't care about size (1 or 2 bays) as long as it looks good, does the job and is black.
