HI Guys not sure if anyone actually interested but the Sentry Mix Two should be in stock in just over a wekk for anyone looking for led fan controller than does 4 pin fans.
Why would you want to control 4 pin PWM fans with a DC voltage fan controller when a motherboard can probably do a much better job natively, considering that it has a way to get at the actual temperatures?
Main reason for it is that although the motherboard does control the fan speeds in my opinion it doesn't do the best job and in order to control the fan speeds you have to plug them into the CPU fan as my sabertooth 990fx runs fans plugged into normal fan headers at max speed.
