NZXT Switch 810 in stock at OcUK!!!!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
NZXT Switch 810 Big Tower Case - White @ £149.99 inc VAT
Experience the pinnacle of chassis design! Switch 810 is an epic hybrid case built for the hardcore PC enthusiast. This full tower chassis introduces a first of its kind concept for more versatility and adaptability to any configuration. It can be modified for superior water cooling or superb airflow through seamless operation. The Switch 810 is the ultimate powerhouse suitable for any type of PC enthusiast – whether you are liquid cooling, silent performance, or extreme airflow. You will have full control to customize all the features of Switch 810 based upon your preference.
Some unique features that set Switch 810 apart is the adjustable Hybrid Fins that reduce sound up to 40-60% when closed or open passageways for maximum airflow. Keep dust out by simply shifting the Hybrid Fins closed. Switch 810 has a rear LED light for illuminating the I/O in the dark, removable HDD cages for bottom radiator installation, a stealth bay, ability to mount triple 120/140mm radiators with 90mm of space, and potential to install up to 7 HDDs. For the first time, NZXT is introducing advanced HDD cages equipped with two 140mm pivot fans for directing airflow to the VGA and CPU. Anything is achievable with this chassis. You can only explore the infinite possibilities of PC expansion with the Switch 810.
- Unique hybrid full tower chassis optimized for extreme liquid cooling, airflow, or silence
- Supports high-end water cooling solutions up to three fans for push and pull configuration: 90mm of internal top space with top 360/420mm and bottom 140/240mm radiator support for unmatched liquid cooling
- Four watercooling cutouts for easy liquid cooling management on the rear panel
- Spacious CPU cutout for mounting high-end CPU coolers without removing the motherboard
- Removable top 5.25” plates to accommodate wide radiators
- Clever hybrid fin design allows the user to choose between maximum airflow or sound reduction
- Innovative right-mounted HDDs for easy hard drive replacement
- Removable HDD pull-out cages and large storage capacity for 7 hard drives
- Equipped with two 140mm pivot fan slots for directing airflow at 15^(0) to the VGA and CPU
- Rear white light for visibility in dark environments with a toggle switch
- Dual high-speed USB 3.0, hard drive dock along with a SD card reader for transfer and quick access to multimedia
- 5.25" hard drive hot swap with SATA III support
- Nine expansion slots for installing EATX motherboards with Quad SLI or Triple Crossfire
- Supreme cooling capacity with up to ten 140/120mm fans
- Stress-free wire management and 23mm clearance in the rear allows for superb wire-tucks
- Ten large specialized cutout holes for easy cable management
- Easily removable bottom filters in the front and rear to prevent dust from entering
- Tool-less 5.25” and 3.5”/2.5” SSD hard drive installation for convenience and ease of accessibility
- Large acrylic window with a view to show off the interior of your rig
- Dimenions: (W x H x D) 235 x 595 X 585 mm
- VGA Clearance Maximum: 375mm (w/out fan), 350 (installed), 285 (full pivot)
- Front Cooling: 2 X 120/140mm (1x 140mm included)
- Rear Cooling: 1 X 120/140mm (1x 140mm included)
- Top Cooling: 3 X 120/140mm (1x 140mm included)
- Bottom Cooling: 2x 120/140mm
- Interior Cooling: 2x 120/140mm (1x 140mm included)
- Drive Bays: 4 External 5.25" Bays / 6 Internal 3.5" Bays
- Screwless Rail Design
- Expansion Slots: 9
- Motherboard Support: E-ATX, XL-ATX, ATX, MICRO-ATX, Mini-ITX
Only £149.99 inc VAT.
ORDER NOW
NZXT Switch 810 Big Tower Case - Black @ £149.99 inc VAT
ORDER NOW
Thumbs up from me. Had one a while now. Pics in project log linked in sig. If anyone wants to know anything give me a shout :)
