NZXT ZERO Case Please?
No way in hell is that case worth nearly £100, Akasa Eclipse/Mirage or something from Lian Li/Silverstone would be SO much better.
Corsair 620w is a very good PSU, Etasis 850w if you plan on going SLi.
Basically it is a Gigabyte Aurora (pretty decent, about £80) but with a much cheaper plastic front than the Aurora has. Because of this the 8800GTX would be a VERY tight fit.
Would'nt get a case with PSU at bottom, bit of a squeeze getting a GTX in these, have a look at Akasa Elipse 62 case, plenty of room for GTS/GTX cards, these are very long and wide cases with exceptional cooling properties, and at a snip of around £100.00 ;) :D what more do you need :eek:
Erm... same as any other PSU it cools it.
I wouldn't buy either of those cases but then I prefer subtle, quality ones to bright lights everywhere and hundreds of fans. For that kind of money you can get:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-027-LL or
http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-AK
Which are better quality cases and both have windowed side panels available if youw ant them.
Out of the two though I would probably get the Antec and be ready to cut it up a little for cable management.
Yeah they are good cases but i really dont like that kind of style.
And i hear everyone go on about the Lian-Li cases are they really that good?
I am now thinking about getting one?
