how well though?Cob said:For C2D's the Gigabyte G33M boards and the ASUS P5K-VM are supposed to clock pretty well.
ah i see, was thinking of getting the cheapest c2d as possible, the e2140 is it?Cob said:Well the two I mentioned are getting to 400mhz FSB and have pretty much the same BIOS options as their ATX big brothers. How good that is depends on the multiplier of the CPU.
The GA-945GM-S2 has no overclocking options. Even if it did it would be severely limited as it's a 945 based board.
But if you've space for a full ATX board then you really should get one.
