O`Clocking, Are My Temps Ok?
5 Feb 2006
Hi all, a few answers would be helpful.
AMD 4600x2 @2.6 from 2.4........217 fsb, 4xht, mem @173 (346) 2.3.2.5 1t (Corsair Twin3200c2pt). Mem won`t clock hence the speed and tighter timings.
Prime95 running on each core overnight........idle 34.......top temps hit 51 degs, no errors or problems. Using AS5, Si-120, Alaska 120 Fan, Kandalf Case.
Are these temps ok? to hot? about right for setup?
Would like to hit 2.7 but maybe wishful thinking!
Thanks In Advance
Ant.....
Yes temps look fine. However if you want you could yet a higher CFM fan.
My rig in the spec runs 34 idle and 47 both cores loaded. Thats with good case cooling m/b temp 32.
Matt
it was a toss up with doing what you said and having tighter timings, i chose the latter of course. Also, whats the max temps without any possible damage to the cpu ?
Thanks Again
Ant.........
Curious, as i`d like to hit 2.7, but dont wanna try really! then again what im going to be using my comp for 24/7 aint gonna be at 100 on both cores like prime of course.
Thanks Dutch.
Ant......
