o rings
2 Feb 2012
i love koolance fittings but thier orange o rings are really lame
so soft and spongy the slightest little pince or knock damages them so easily
normal ones of the same diameter and thickness tho dont compress enough on the quick connects at least as ive tried witha normal black one of the same size
however i did by a pack of assorted orings from B&Q for like 1.45 and used one that was just slightly smaller in diameter and found that as a result of it stretching and making it thinner the quick connects close and seal perfectly
anyone else noticed this ptoblem with the o rings on QDC`s and have an idea think i will by a couple spares tbh
i will add im not exactly rough with the connections they took a really light knock that was all
