I have put a few post's in here over the last few days (thanks to those that replied) But the problems I have is having managed to use the ASR to restore the OS everything seems fine Until I have to reboot the pc for any updates. It is at this point everytihng goes south, all that happens is the splash screen loads up and things look good but then everything stops. I am not able to get it into safe mode as again the System32 files start to load and then all of a sudden evertying stops the CPU is running but no acitivy from the HD?I have run chckdk via dos on the drive and no problems were found.
In essence if I have to reboot or turn the pc off for any reason the OS is lost and I have to ASR all over again.Has anyone got any ideas as to the potential cause?
