I'm looking for a new case, and like compact cases. I like the look of the Lian Li O11 Air Mini.
I have a full ATX mainboard and a NZT Kraken X63 (280mm rad) that cools it. This build will have either a 4080 or 7900 XTX that I'd like vertically mounted.
Looking at the spec, I can only fit a 280mm rad at the front when using a configuration that supports ATX and vertical mount. I know it'll fit but is it going to be awful for air flow? Would bringing in air from the side and underneath the GPU be enough?
I've seen some people say that you can just about fit a 280 at the side.. but then this video suggests front mounted radiator (intake) side fans as exhaust and bottom fans as intake works best. This isn't vertical GPU mount though.
Just wondering if anyone here has done a similar build?
