O11-Dynamic-mini will my PSU fit?
29 Jul 2013
Sheffield
I have the evga supernova g3 750
some say you can fit this PSU inside the case but have to have the back cover off, some say you can't fit it at all.
I need a new case, this appears to be the only one I like but I don't think it will fit and I'm not sure if the bigger version is going to be a bit too big (my current case is a hotbox gamemax Polaris)
other hardware in case I've missed something else but I believe the rest will fit
x370 k7 motherboard
2070 super msi gaming trio
NZXT KRAKEN 280MM ALL-IN-ONE HYDRO CPU COOLER WITH RGB
thanks guys! :)
O11 dynamic mini doesn't support a full size psu, it uses SFX or SFX-L size (ie the smaller ones, both length options).
The EVGA g3 is a full size psu not an sfx..... if you want to keep the psu you'll need to move up a level to the normal O11 Evo.
any ideas if it will fit if I leave the back panel off though? as I'm sure I've seen someone say this is an option if you don't mind the back pannel being off
I don't have the case, I have the normal o11 evo... but I'm not sure why you'd even consider that because it would literally be 'hanging loose'... I wouldn't personally take that approach.
hmm maybe I'll go for the Air or Fractal Design North instead then
Apparently the Dynamic Mini does fit a full size PSU but it takes a bit of modding as you need to put it in the HDD area instead of the PSU area.
This is what I read when I purchased my Dynamic Mini, but I just got a SFX PSU instead
See i was thinking something like this but some people say there's no way some people say yes with the pannel off some people say yes but you can't screw it some people say you can screw it but you'll not get the middle section for ssd mounting or something so it's very confusing
guess I will hold off and wait till a case i prefer comes out I like the look off, the price of a 1000w SFX PSU is ridiculous just for me to get some better airflow
