O11 XL with Seasonic Right angle 12VHPWR cable and a 4090
17 Mar 2017
Manchester
I am currently using a 4090 with a Vertex GX 1000 and Seasonics straight 16 pin to 16 pin 12VHPWR cable that came with the PSU which I bent myself and has been fine for since release, It isn't forced and isn't quite touching the side glass panel but I wanted to get the correct right angle cable and do the job properly so am waiting for the new Seasonic 12 + 2 cables that should be released soon and it looks like they are the same right angle plug that comes with their original right angle cable more specifically this one...
Does anyone have this combination and does it fit with the side panel fully closed properly with a 4090?
Thanks in advance.
